Hello, I'd like to purchase the new Intel NUC8i7BEH, with the 8559U processor.
My question is if it supports XMP profiles of the system RAM.
I'd like to buy this kit:
https://www.amazon.com/G-Skill-3200MHz-SO-DIMM-Upgrade-PC4-25600/dp/B0799MLW77/ref=sr_1_1?ie=UTF8&qi... https://www.amazon.com/G-Skill-3200MHz-SO-DIMM-Upgrade-PC4-25600/dp/B0799MLW77/ref=sr_1_1?ie=UTF8&qi...
Yes, it supports XMP profiles. Whether this means that it will support these DDR4-3200 SODIMMs is something you will need to investigate. I would be checking the information at http://compatibleproducts.intel.com/ProductDetails?activeModule=Intel%C2%AE%20NUC http://compatibleproducts.intel.com/ProductDetails?activeModule=Intel%C2%AE%20NUC to ascertain whether any DDR4-3200 SODIMMs have been found to be compatible.
Hope this helps,
Thank you kindly for your reply.
Although .. the compatibility list has only up to 2400mhz modules.
