Does nuc7i7dnhe support DDR4-2666 Memory?
which type memory prior?
Here you can see the memory tested and approved by Intel for this NUC. In this table you may find two SODIMs with 2666MHz frequency. http://compatibleproducts.intel.com/ProductDetails/ExportPeripheralInfo?moduleName=Intel%C2%AE%20NUC... http://compatibleproducts.intel.com/ProductDetails/ExportPeripheralInfo?moduleName=Intel%C2%AE%20NUC...…
Because the processor on this Intel® NUC only supports DDR4 speeds up to 2400 MHz, higher-speed SO-DIMMs operate only at the 2400 MHz memory timing.
Leon
