Intel® NUCs
12323 Discussions
Does the TOSLINK on NUC8i7HVK only support 48000Hz sample rate?
archon
The technical specification says 44.1/48/96/192KHz are supported on all analog outputs, however it said nothing about TOSLINK.
So is 48000Hz the only sample rate supported by TOSLINK output on NUC8i7HVK?
AndrewG_Intel
Hello archon
Regarding your inquiry about sample rates for TOSLINK* supported on the Intel® NUC Kit NUC8i7HVK, please allow us to look into this and as soon as we have more details available we will be posting back in this thread.
Andrew G.
AndrewG_Intel
Hello archon
Thank you for your patience in this matter.
Regarding your inquiry, we would like to inform you that the TOSLINK on the Intel® NUC Kit NUC8i7HVK only supports a 48000Hz sample rate. TOSLINK is by definition 48000Hz sample rate capable only.
Should you have additional inquiries, please let us know.
Andrew G.
