I am looking for an updated driver for the 'Standard SATA AHCI Controller' on my Intel NUC8i5BEK. The current driver is 'storahci.sys' and is dated 2006-06-21. I have tried looking for a driver update with no success. I have had repeating blue screens of death on this so-called new computer, with example error codes 'DPC Watchdog Violation', 'BAD POOL CALLER', to name a few. When I googled the errors, it suggests that the Standard SATA AHCI Controller driver may be the problem and to up-date it the driver to 'iastor.sys'... So where can I get this driver? All the other computer drivers have all been updated (using the Intel Driver & Support Assistant) except this one... Any help would be much appreciated.
Do the following:
- Download the latest Chipset Device Software package referenced for this NUC (here: https://downloadcenter.intel.com/download/27998/Intel-Chipset-Device-Software-for-NUC8i7BE-NUC8i5BE-NUC8i3BE?product=126148).
- Extract the ZIP file contents into a temporary folder.
- Open a Command Window and made this folder the current.
- Execute command "SetupChipset /overall".
- Reboot.
- Delete temporary folder.
What this does is make sure that every driver is fully updated. It isn't actually installing any drivers (in fact, the package doesn't ever install any drivers); it is just optimally configuring the driver supplied in the Microsoft catalog. It should set the date to the right value.
Do the following:
- Reboot.
Thank you Scott... I will give it a try and let you know how it works out....
Susan
Hope this helps,
