Intel® NUCs
12341 Discussions
Driver problem with NUC8
Rokko55
Hello, I have a NUC 8, BOXNUc8iBEK2, Ser.-Nr. G6BE85000PJY, 12/2018, Constains IC-1000MJ-9560D2, Constains FCC ID: PD99560D2, the drivers for PCI data acquisition and signal processing controllers: VEN_8086 & DEV_9DF9 and PCI device: VEN_8086 & DEV_9DA4, cannot be installed or updated. I downloaded the Intel Driver Support Assistant and updated everything, but these drivers cannot be loaded. I've tested this on Windows 10 and Windows 11. The drivers cannot be loaded. Can you help me?
Best regard
Rokko
LucF
I also had some unrecognized devices and I solved it by installing:
Intel Chipset Device Software
https://www.intel.it/content/www/it/it/download/19304/intel-chipset-device-software-for-nuc8i7be-nuc...
Intel Management Engine Consumer Driver
https://www.intel.it/content/www/it/it/download/19260/28215/intel-management-engine-consumer-driver-...
Check that your model is listed in the compatible NUCs.
Ciao.
Rokko55
Hello, the chipset driver worked! Thank you for your help!
Mfg
Rokko
