Community
cancel
Showing results for
Search instead for
Did you mean:
FNegr1
Dual displays on thunderbolt 3 / USB-C port
Hi, i have already read others discussions about this and i came with a possible solution for my case (need three displays connected), but i need confirmation.
In Intel product compatibility page for NUC7i7BNH it is listed an USB Type-C docking station (UD-ULTCDL) from Plugable.
I wonder if it is really full compatible as it says on this page, assuming it will work for connecting 2 monitors on the USB-C port. As my interest is only on that I need to know it before buying the dock that is very expensive.
Community Manager
Hello
Thank you for contacting Intel Technical Support,
We received your inquiry and I understand that you are looking for information about display supported. Please accept our apologies for any inconvenience this may be causing. We will be more than happy looking for a solution.
Based on the information provided for the model on the NUC and the docking model I will like to share with you that that is validated by Intel® you can review that information on the following link on the section Thunderbolt™ and USB Type C Devices
http://compatibleproducts.intel.com/ProductDetails/ExportPeripheralInfo?moduleName=Intel%C2%AE%20NUC... http://compatibleproducts.intel.com/ProductDetails/ExportPeripheralInfo?moduleName=Intel%C2%AE%20NUC...
Leonardo C.
Community Manager
Hello FelipeBr
I was checking your case and would like to know if you need further help. If so, please do not hesitate in replying back.
Leonardo
FNegr1
I bought a cabblematter thunderbolt to dual displayport adapter for connecting both displays via thunderbolt but that doesn't work. I've already installed the last thunderbolt firmware for NUC.
My questions are:
1. If a simple dualdisplay adapter does not work why should a dock will? ( For connecting dual monitors in thunderbolt)
2. I am not an specialist but this seems to be a program code base problem. Is Intel working on get this working? (thunderbolt dual display adapter)
I have already spent lots of money buying cables and adapters, and since I am on Brazil and cannot test the product before buying it, the acquisition of the dock station is temporary out of question for me.
I don't want to be disrespectful but I just don't believe it is going to work. Like some other wrong information providing by Intel regarding this specific issue. (dual monitors on usb-c / thunderbolt port)
Community Manager
Hello FelipeBr
Thanks for your response.
I understand that the adapter on your possession did not help you, we know that on the market there are several adapters on that could be used for the same propose, that being said, Intel would not be able to validate all of them; on the previous link you were able to verify the once that have been validated for that use.
To obtain more information on your problem could you provide the fooling information:
Could you run the Intel® System Support Utility for Windows? Please attach it to the thread. Could you provide us the model of the adapter that you have?
Thank you,
Leonardo C.
FNegr1
The model of the adapter is:
Cable Matters Thunderbolt 3 to Dual DisplayPort 107006
The file provided by Intel System Support Utility is attached below.
Community Manager
Hello FelipeBr
Thank you for your response.
Doing more research on the adapter that you have I was able to find the following link http://kb.cablematters.com/index.php?View=entry&EntryID=68 http://kb.cablematters.com/index.php?View=entry&EntryID=68, in which the manufacturer informs of comparability problems, it also has information on the adapter behavior; have you tried to contact CableMatters to verify if they have more troubleshooting steps for the adapter?
Leonardo C.
FNegr1
Hi Leonardo C.
Thank you for replying.
I looked again at the link provided by you (i have been there before) and actually they say the problem is with some computers that do not support dual displays under one thunderbolt 3 port, so, the issue is with intel NUC not CableMatters.
I don`t want to be rude but you did not answer my previous questions:
Thank you.
Community Manager
Hello FelipeBr
The USB Type-C docking station (UD-ULTCDL) that you ask on the previous post has been validated by Intel to work on the dual display as well as the other models that are on the list provided on the link above,
On the matter of the program code base problem (driver), it has been used for configurations with the validated devices and worked fine.
Due to the wide variety of adapters and docking stations on the market is not possible to test/validate all of them, therefore, the list of tested peripherals we provide on our website
Leonardo C.
Community Manager
Hello FelipeBr
Leonardo C.
nfior1
Dear Leonardo,
Sorry that I replied to a previuos post but I did not understand how to create one.
I have the NUC7i7BNH which is equipped with an hdmi output and a USB-C output.
I had two display connected to it. One directly from the NUC HDMI port, the second one connected trough the USB-C adapter.
After few months the adapter stopped working, I bought a different one and after few more months it also stopped working. None of them was one of the approved on
I wish I can get one of the two approved adapter listed here http://compatibleproducts.intel.com/ProductDetails/ExportPeripheralInfo?moduleName=Intel%C2%AE%20NUC... http://compatibleproducts.intel.com/ProductDetails/ExportPeripheralInfo?moduleName=Intel%C2%AE%20NUC...
But it is impossibile to get it in my country both the VisionTek 900817 and the Ysimda 4454033.
I tried in buying a cable that has in one side the usb-c and the other side the display port. But It wasn't working.
How can I solve this issue? which option I have?
Thank you for your support.
Nicola
Community Manager
Hello PizzoScalino,
I understand you are currently experiencing and issue.
However, We apologize for any inconvenience. Please submit a new thread since we handle every case individually and every scenario is different even if the same product is being used. The next agent will be able to further assist you on this matter.
David V
nfior1
thank you for your message.
I understand that.
Can you please be patient and tell me how to submit a new thread?
I'm a newbie!
thank you
