Intel® NUCs
12126 Discussions
Dualscreen "no signal" intel nuc7i5bnb usb-c to dp 1.2 with latest bios and driver need to unplug and replug to work with the second screen
jingaling
Hi there i got recently connected my nuc NUC7i5BNB with the latest bios 0072 and drivers on a updated win 10 machine with two 2K screens the AOC Q3279WG5B with this cable https://bit.ly/2GbbsWb
If i connect the second screen i get a no signal notification on the second screen connected with usb-c to dp 1.2 both running at 60hz if i unplug the usb-c cable from the nuc and plug it back in the second screen is working again. For me i need a solution for the unplug and replug the cable all the time i dont have a spare cable to test by the way.
Wanner_G_Intel
Hello jingaling, Thank you for joining this Intel Community. To better assist you, we would like to know if you are using a daisy-chain connection: 1. Intel® NUC (USB Type-C) to main monitor (DisplayPort*). 2. DisplayPort* Out on the first monitor to DisplayPort* In on the second monitor. If your connection is different, please let us know. It is worth mentioning that DisplayPort* 1.2 MST should be supported by the monitors. I was not able to find the monitor specifications with the model you posted. If possible, please provide us with a link or check the manual. Also, try enabling DisplayPort* 1.2 on your monitor. Wanner G. Intel Customer Support Technician Under Contract to Intel Corporation
jingaling
Hi Wanner,
Both monitors already enabled the display 1.2 option these monitors i am talking about https://eu.aoc.com/nl/products/q3279vwf/specs connection 1 intel nuc to main monitor with hdmi from nuc to hdmi in monitor 1 and connection 2 usb-c to second monitor with usb-c to displayport 1.2 cable. So two different cables both from the intel nuc to 2 monitors main is with hdmi and second is with usb-c to displayport cable.
Wanner_G_Intel
Hello jingaling, First, please try doing a clean installation of the latest graphics driver: 1.Disconnect your unit from the internet. 2.Uninstall both the Intel Graphics driver and the Intel Display audio driver. To do this, please follow the steps on the link below under these sections: -Uninstalling the Intel Graphics Driver via the Device Manager Method -Uninstalling the Intel® Display Audio Driver or the Intel® HDMI Audio Driver via the Device Manager Method. https://www.intel.com/content/www/us/en/support/articles/000005598/graphics-drivers.html 3.Restart your computer. Go to the device manager and check if Windows installed another version of the graphics driver. If it does, please remove it and restart your computer one more time. Repeat the process until you get the Microsoft Basic Display Adapter. 4.Once you do, please proceed with the clean install of the latest graphics driver: For Intel® NUC Kit NUC7i[x]BN Intel® HD Graphics Driver for Windows® 10 for Intel® NUC Kit NUC7i3BN, NUC7i5BN, NUC7i7BN Version: 24.20.100.6286 (Latest) https://downloadcenter.intel.com/download/28208/Intel-HD-Graphics-Driver-for-Windows-10-for-Intel-NU... 5.Once the latest driver has been installed, you may enable the internet connection again. In addition, make sure that you are running the latest driver and firmware udpates. Monitor Driver LCD Monitor User Manua https://aoc-pim.s3.amazonaws.com/manuals/Q3279VWF/Q3279VWF_English_1_0.pdf Wanner G. Intel Customer Support Technician Under Contract to Intel Corporation
Wanner_G_Intel
Hello jingaling, If you have any further questions, we will be glad to help you. Wanner G. Intel Customer Support Technician Under Contract to Intel Corporation
jingaling
I bought another cable and that fixed the problem thx for the help.
