Community
cancel
Showing results for
Search instead for
Did you mean:
JMøll1
ESXi 6:5 install on 7i5BNH: nfs41client failed to load
Hi.
I try to install ESXi 6.5 on my NUC7i5BNH but the network is not detected and I have upgraded the NUC to BN0061 FW.
/Jens
Community Manager
Hello JamCoop,
Thank you for joining the Intel® NUC Community. I am sorry to hear you are having issues with the network.
I would like to share with you that Intel does not test and validate Intel® NUC with this operating system, the only fully supported operating system for this Intel® NUC model is Windows® 10. From our end there are no drivers for ESXi 6.5. I was double checking for more options for you in this case, but I was able to find that VMware also confirms that this specific model will not work with ESXi 6.5. You can check the VMware Compatibility Guide here: https://www.vmware.com/resources/compatibility/search.php VMware Compatibility Guide - System Search. Lastly, you can also try to get more information from their forum support: https://communities.vmware.com/community/vmtn/vsphere https://communities.vmware.com/community/vmtn/vsphere
Amy C.
