Intel® NUCs
Assistance in Intel® NUC products
All support for Intel® NUC 7 - 13 systems is transitioning to ASUS. Read more.
13495 Discussions
Ethernet Connection (2) I219-V is limited to 100Mbps.
TheSquale
I would like to ask again a question that had not been answered by the applicant
I have the Intel (R) Ethernet Connection (2) I219-V adapter but it is limited to 100Mbps.
The questions was:
1. What is the Operating System used?
W10 21H1
2. Model of your motherboard/system.
BIOS
Version
BIOS Date: 01/03/18 10:00:19 Ver: 05.0000B
Date
03/01/2018
Mother board
Builder
Intel corporation
Modèle
NUC6i3SYB
Version
H81132-505
3. Is this is newly built system? If no, for how long is the system working fine?
I have just switched to ethernet before I was on wifi
4. When was the issue first encountered?
Today
5. Is the 300Mbps a guaranteed rate form your Internet provider?
I have fibet up to 500Mb
6. Do you have another system or computer that you can use to test the speed of your Internet? This will help in isolating the issue.
I have a laptop on same network and I have Gigabit
7. What is the current driver version installed on your system and where it was downloaded from?
Version12.19.0.16
8. Can you share if the Speed & Duplex settings on Advanced tab property of the Ethernet Controller is set to Auto Negotiation?
Yes it is in Auto Negotiation
9. Please double check if the established connection speed in the settings can reach 1Gbps. To confirm this, go to Network and Internet Settings; View your Network Properties and scroll down to Link speed (Receive/Transmit).
Don't understand, actually I am in 100Mo
AndrewG_Intel
Hello @TheSquale
We would like to inform you that due to the Intel® NUCs based on the board NUC6i3SYB (Intel® NUC Kit NUC6i3SYH and NUC6i3SYK) have been discontinued, Intel Customer Service no longer supports inquiries for it, but perhaps fellow community members have the knowledge to jump in and help. You may also find the Discontinued Products website helpful to address your request.
Note: You might need to search for the proper Product Category and click on the "Show more" link if the product is not visible in the top rows.
Andrew G.
TheSquale
Ok, thank you very much
