Intel® NUCs
12305 Discussions
Every time I move my mouse, there is static noise in my headset.
AMai01
I'm using a G502 Proteus Spectrum Mouse and a Steel Series Arctis 3 Bluetooth. My headset is plugged in to my NUC6i7KYK. I'm using a headset splitter and plugged it in to the mic and audio ports. Thank You for your help.
jhold7
hi
Yes this is a pretty well-known problem there should be multiple threads here in regards to this issue.
If I recall correctly it's your sound ship picking up electrical disturbance. I believe a third option is to get a sound card but I could be mistaken. It's not your headphones and it's not your mouse, it's the motherboard
Alberto_R_Intel
Hello AMai01, Thank you for posting in the Intel® Communities Support.
I just wanted to check if the information posted previously was useful for you, if the problem persists and if you need further assistance on this matter?
Albert R.
A Contingent Worker at Intel
AMai01
Hello Albert,
I can't really do much with the motherboard on my Intel Nuc, so I just have to get used to it. For the sound card I don't really know how to install one on an intel nuc. Also if I use bluetooth, they static is louder, so I have to unplug my headset to not hear it. Thanks for your assistance.
Alberto_R_Intel
AMai01, You are very welcome, thank you very much for letting us know that information.
I will send you a private message, please verify your inbox.
Albert R.
Alberto_R_Intel
AMai01, I just wanted to check if you received my last private message regarding the warranty status of the Intel® NUC and if you need further assistance on this matter.
Albert R.
AMai01
Hi Albert,
Yes I saw the message about the warranty. I can’t do anything because I got it off someone I know. I will just have to get use to it. Thank you for trying to help.
Alberto_R_Intel
AMai01, You are very welcome, thank you very much for providing those details.
No problem, we completely understand and hopefully the problem will get fixed someday.
Any other inquiries, do not hesitate to contact us again.
Albert R.
