Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Extra boot menu on Atom NUC DE3815TYKHE
We are using many of the Atom NUCs for a digital signage installation. We have noticed that on some occasions when the power is cut abruptly to the unit, a different boot menu sometimes appears when power is reconnected.
The menu displays:
TYBYT10H.86A.0041.2014.1224.1255
[ESC] Normal Boot
[F2] Intel Visual BIOS
[F4] BIOS Recovery
[F7] Update BIOS
[F10] Enter Boot Menu
[F12] Network Boot
Disconnecting and reconnecting the power causes the unit to boot normally. We are using the built-in 4GB eMMC storage to run a Linux distribution.
Does anyone know how this menu can be skipped so the unit will always boot straight into the OS?
-Jonathan.
Highlighted
1 View
Re: Extra boot menu on Atom NUC DE3815TYKHE
Are you holding the power button at some point by any chance? See power button menu in page 66.
http://downloadmirror.intel.com/23745/eng/DE3815TYBE_TechProdSpec07.pdf http://downloadmirror.intel.com/23745/eng/DE3815TYBE_TechProdSpec07.pdf
Did you try changing the option "After Power Failure" in BIOS?
Highlighted
1 View
These machines are mounted on the wall, so I don't think the power button is ever being pressed on startup.
After Power Failure is set to "Power On".
"Wake System from S5" is selected.
"Wake on LAN from S4/S5" is selected, but we probably do not need this option.
"USB S5 Power" is deselected.
"Wakeup Hour" is set to 4. The other "Wakeup *" options are set to 0.
-Jonathan.
