AMD says portrait mode is supported, but will not answer questions, they say you have to go to the manufacturer which is intel, so how do I put this in portrait mode using Eyefinity?
Hello DDalt3,
To better assist you I would like to gather some additional information from you:
- How many monitors are you using? And how are the monitors connected?
- Please confirm the operating system and its version
Please run the following tool and attach the reports generated.
Intel® System Support Utility (Intel® SSU)
Intel® SSU Download link
Open the application and click on "Scan" to see the system and device information. By default, Intel® SSU will take you to the "Summary View".
Click on the menu where it says "Summary" to change to "Detailed View".
To save your scan, click on "Next", then "Save".
Esteban D.
Intel Technical Support Technician
I am running windows 10 pro 32 gigs of memory with November 2019 1019 update... 3 1080p monitors they can be connected in any way, currently 2 usb-c, and one via the back HDMI interface
Hello DDalt3,
Were you able to run the Intel® System Support Utility (Intel® SSU)?
if so, please attach the report.
Esteban D.
After reviewing the report provided we noticed that there is a Radeon™ Software update available.
Please update it to the latest version and check for the feature.
You can find the software in the following link.
Esteban D.
Technician
I have updated and I still don’t see how I create a portrait mode eyefinity configuration? Can you please show the step by step?
Hello DDalt3,
Thank you for your response. Now that the software is up to date try the following steps:
First, change the orientation of the monitors from Display settings. Check the following link to do so. All monitors must be in “portrait” mode.
After that, please check the steps provided by AMD* to configure multiple displays to run in Eyefinity mode.
Links to third-party sites and references to third-party trademarks are provided for convenience and illustrative purposes only. Unless explicitly stated, Intel® is not responsible for the contents of such links, and no third-party endorsement of Intel or any of its products is implied.
Esteban D.
That worked thank you
