Intel® NUCs
12307 Discussions
FPC Cable to connect D4 board to D430 depth module
DMotw
Hello, I am interested in using an FPC cable to connect the 50-pin receptacle on the D4 processor board (I-PEX part no. 20709-050E) to the respetcive connector on the D430 depth module (I-PEX part no. 20708-050E). Page 47 on the RealSense 400-series datasheet (https://software.intel.com/sites/default/files/Intel_RealSense_Depth_Cam_D400_Series_Datasheet.pdf https://software.intel.com/sites/default/files/Intel_RealSense_Depth_Cam_D400_Series_Datasheet.pdf ) seems to suggest that the cable is custom designed by the system integrator. Are these cables readily available for purchase? If not, should one get the two I-PEX connectors and design a custom flex circuit to interface between the two?
Thank you for your help!
MartyG
For the helping of others who may want to comment, here's a reply I left on another post (new comments left on old questions do not show on the forum front page).
Diptivm, history indicates that whilst you may be able to design a custom cable, the IPEX connector parts are extremely difficult to obtain, as requests by individuals for the parts on the iPEX website go unanswered as far as I have heard.
I do remember that a Far Eastern source for IPEX is Dai Ichi Seiko, IPEX's parent company.
https://www.daiichi-seiko.co.jp/english/spn/index.html DAI-ICHI SEIKO CO., LTD.
MartyG
