Intel® NUCs
Assistance in Intel® NUC products
All support for Intel® NUC 7 - 13 systems is transitioning to ASUS. Read more.
13490 Discussions
Fan is not increasing its rate as it should for the custom mode inside BIOS cooling settings
saturn32
Hi Folks,
I have recently updated the BIOS of my NUC8i3BEH from version 0078 to 0081, hoping it would solve following issue. Whatever custom mode I configurate inside BIOS for cooling it doesnt seem to work. The fan speed is not behaving differently.
Fan Control Mode: Custom
Primary Temperature Sensor: Processor
Fan off capability: off
Minimum Temperature: 65
Minimum Duty Cycle: 35
Duty Cycle Increment: 4
Second Temperature Sensor: Memory
Minimum Temperature: 60
With this settings fan barely exceeds 4000 rpm according to HWInfo even with processor temperatures close to 90 °C. I use the cool mode instead and the fan goes over 4000rpm and CPU doesnt get that hot. But I would like even lower temperatures.
After Bios update (0081) , I loaded default settings and entered inside the BIOS again to change to custom mode. Am I doing something wrong?
Joan
