Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Feature Request: Better BIOS Upgrade Warnings
Jump to solution
Hello. New NUC7i5BNK user here.
Yesterday I went to upgrade my BIOS from version 49 to version 50. There are general warnings for various things, including "If you are trying to downgrade to a previous BIOS version and its Intel® ME Firmware version is older than that currently on the motherboard, then the downgrade is NOT supported."
There is no mention that Bitlocker-enabled installations will require entry of a Recovery Key after a BIOS update. I've had many Bitlocker-enabled installations in the past, none of which required the Recovery Key after a BIOS update.
So I upgraded. Discovered my Recovery Key was needed, which was 20 miles away from the NUC location. I figured I would downgrade back to 49 as a quick fix. Even though the ME Firmware version was the same between 49 and 50, the downgrade was not allowed.
My assistant was headed to the office and needed the computer.....so I made the 40 mile round-trip for the key.
Intel, I think it would be a good idea to:
1. Provide a specific warning that BIOS upgrades on systems with Bitlocker enabled will require a Recovery Key.
2. Specifically warn when you can't downgrade to the most recent preceding BIOS release.
Thank you.
Accepted Solutions
Highlighted
Community Manager
Hello trueblue,
Thank you for contacting Intel® technical support. I am truly sorry for all the inconvenience that you experienced.
We are grateful for the feedback that you are providing with, and we will take it in consideration for future BIOS development.
I hope that you have a very nice day.
Xavier A.
Highlighted
Community Manager
Hello trueblue,
Xavier A.
Highlighted
Community Manager
Hello trueblue,
I was checking your case and would like to know if you need further assistance. If so, please do not hesitate in replying back.
Xavier A.
Highlighted
No additional assistance needed on this issue. Would like to see you incorporate my suggestions in the future. Thank you.
Highlighted
Community Manager
Hello trueblue,
You are very welcome. Have a nice day.
Xavier A.
