Why was the following added and why does it look so bad:
”Updated BIOS setup to provide URL address and QR code availability leading to NUC support webpage.”
I’m sure everyone knows how to use google search, this is not needed and looks TERRIBLE!
Bottom left corner, different font in italic, underlined like its a hyperlink on a bios splash screen... What were you thinking Intel?? It looks a mess!
Can you remove it from the next BIOS update to bring back it’s clean look or at the very least centre it, change the font, take off the italic and underline as you disabled downgrading the BIOS as well
Shaun, Thank you for posting in the Intel® Communities Support.
Thank you very much also for your feedback, for Intel® is very important the comments and suggestions from all of our customer, so I will send your remarks to the proper department for the to be aware of your observations.
Albert R.
A Contingent Worker at Intel
If the team responsible for it insist on keeping it can they at least add the option to disable it, it seriously looks bad and is definitely unnecessary
Shaun, Thank you very much for your response.
Sure, I will also provide this suggestion to the proper department for them to take into consideration that option.
Albert R.
I also dont like it but i used to it.... I dont enter the BIOS daily and i dont look a the boot window always
BTW, what should be the benefit of it? I dont see any.
How and why should it be used?
An option to disable it would be really nice
Cheers
svenry
according to this thread an option to disable it is in work, great!
Good to see I’m not the only one that noticed this and thinks it’s pointless and looks terrible!
