Community
cancel
Showing results for
Search instead for
Did you mean:
DPers1
New Contributor III
Fix(work around) for missing taskbar icons on extended display
Occasionally(rarely) when the NUC( NUC7i5BNHXF)wakes up from sleep the Icons on my extended display(TV on HDMI port) taskbar go missing.
The only icons showing is Windows and Taskview.
I just discovered that clicking on the windows Icon that brings up the windows side menu also brings back the Icons to the Taskbar.
I clicked on the windows icon on the extended display but I have a feeling that you will get the same result if you click it on your main display.
I have my taskbar set as Hidden, not sure if that has anything to do with this issue. Or maybe it has to do with Optane?
Before I discovered this I had to reboot to get the icons back, clicking the win Icon to do it is OK with me.
Community Manager
Hello Thaidroid,
Thank you for joining the Intel Community Support.
Thank you for the information provided. Hopefully, other community peers facing the same issue will benefit from your experience with the NUC7i5BNHXF.
It is worth noting that your feedback is highly appreciated.
Wanner G.
