Intel® NUCs
12307 Discussions
GSkill Memory on NUC7 question
MSall
Hello!
Please, can I use the GSkill memory code F4-2400C16D-32GRS on NUC7i7BNH, without problems?
I couldn't find it listed on Intel's compatibility list nor GSkill QVL....
by the way, the Set is 2 x 16 GB.
Link to product at GSkill site here:
https://www.gskill.com/en/product/f4-2400c16d-32grs https://www.gskill.com/en/product/f4-2400c16d-32grs
Thank you!
n_scott_pearson
Super User Retired Employee
I don't see anything obvious that would preclude their usage. I wonder why I am not seeing any GSkill memory in the compatibility tabled, however.
Community Manager
Thank you very much for contacting the Intel Communities Team, Marculino. I will be more than happy to assist you.
The list of the list of compatible products is just a reference for the customer that has hardware that has been tested and validated by Intel. This does not mean that other RAM stick will not work with the NUC nevertheless, with other using RAM sticks, the results may vary.
By checking the G.Skill F4-2400C16D-32GRS, I can see that the frequency of this RAM is 2400MHZ. Please note that the https://ark.intel.com/products/95065/Intel-NUC-Kit-NUC7i7BNH NUC7i7BNH supports DDR4-2133MHz.
Antony S.
Community Manager
In addition to my previous post, please make sure the G.Skill memory modules come with an SPD chip so they can automatically adjust to the system's speed.
Antony S.
MSall
Thank you both N. S. Paerson and Antony S.,
Concerning the above frequency, I understand that it will drop when memory in use inside the NUC, however the salesman near me has no other item for sale....
Ok, thank you so much!!!
