My new Ghost Canyon that has been working smoothely for a month. The Nuc now stuck on the Intel Nuc splash page with the usual options :
- F2 to enter Setup,
- F7 to Update BIOS,
- F10 to Enter Boot Menu.
None of these options work. Just still locked on this screen for more than 5/6 minutes, then it starts the operating system [please see the attachment].
The Nuc works normally and starts the operating system quickly as soon as the power cable is unplugged for a few seconds then replugged back in. [tested with the internal M2 DD and also with a bootable usb stick].
I also did the following tests :
- I removed every device plugged in and no change,
- I removed the memory one stick at a time and no change,
- I plugged the monitor in using HDMI instead of display port and no change,
- I tried booting to an ubuntu USB stick and am unable to boot from that,
- Flashing old bios version “QX0052“ and no change [flash was done using the function F7, using recovery method with power button and also security jumper].
Here is my hardware configuration :
- RAM : Crucial 2 x 32GB DDR4-2666 SODIMM
- DD : Crucial MX500 M.2 SATA SSD
- Running BIOS QX0054
Any help will be welcome.
Thanks!
Hello Theamy,
If you will proceed with the warranty, feel free to provide this thread as a reference.
Maria R.
Hello Theamy,
Thank you for posting on the Intel* Community.
With the information you provided I will proceed to check this case internally, please expect an update soon.
Maria R.
Can’t wait for having your final answer.
Hello Theamy,
Thank you for patiently waiting.
We were trying to replicate this behavior in our Intel* lab, but we did not get the same results.
It seems to be a problem with the NUC's bios. In this case, our recommendation is to contact our internal support directly to verify the warranty of your unit:
- U.S. and Canada: Intel Customer Support NA
- Europe, Middle East, and Africa: Intel Customer Support EMEA
- Asia-Pacific: Intel Customer Support APAC
- Latin America: Intel Customer Support LAR
- Chat: Intel Customer Support Chat
Maria R.
Hello Theamy,
Maria R.
