I ran the DSA on my NUC8i7BEH but it showed everything up to date, however, the download site, specific to my box showed this HDMI update, so I ran it.
The thing is, when I did it, I had no Program Device Certificate to uncheck and when I do the final Get FW Version it says “CMDB: No data!” but the Driver and FW files have been updated. The Program Customised Data Block remained checked during the process and when I browsed for a file for this item there appeared to be nothing to put in.
I have run it three times now with the same result. But I have to say the quality of the display is noticeably better so should I be concerned?
Thank you.
Hello JRayn3,
Thank you for submitting your question on this Intel® Community.
To better assist you, we would like to gather the following information about your setup.
- Please generate a system report with the Intel® System Support Utility (Intel® SSU) and attach it to this thread.
- Intel® SSU Download link.
- Open the application and click on "Scan" to see the system and device information. By default, Intel® SSU will take you to the "Summary View".
- Click on the menu where it says "Summary" to change to "Detailed View".
- To save your scan, click on "Next", then "Save".
- Are you following the steps available at the Update Guide (PDF)?
Wanner G.
A Contingent Worker at Intel
Dear Wanner G.
Thank you for your response
In reply to the first part, I attach the system report.
In reply to the second part, I read the Update Guide thoroughly before attempting the update but as you can see from the screen shot my layout is different from that shown in your Guide in that some items are missing.
Everything seems to be working OK and as I said in my first post I am sure there has been an improvement.
I look forward to hearing from you.
Hello JRayn3,
Thank you for your input.
We will attempt to replicate this issue and get back to you as soon as possible.
Wanner G.
Hello JRayn3,
We would like to update this thread.
As you were saying, the steps to update the HDMI* Firmware Update instructions are a little bit different. However, we performed the update without receiving any "CMDB:No Data" message at the end of the update.
- We browsed to the /bin folder for the Driver and FW Files.
- After that, we unchecked the Program Customized Data Block.
- Then, the update was completed without displaying any "CMDB:No Data" message.
Given that you were able to install the new HDMI* firmware version, you should not experience any graphics or video quality issues.
Also, what we can do is document your feedback about the Update Guide so that it can be updated to reflect the new HDMI* firmware version.
Wanner G.
Hello JRayn3,
We are glad to know that the issue was resolved successfully.
We will close this inquiry. If you need further assistance, please post a new question. We will be glad to assist you.
Wanner G.
