Intel® NUCs
12325 Discussions
HDMI & USB-C vedio output problem
LiXinxing
Does the HDMI port and USB-C (DP1.2) which connect to a VGA dispaly can work at the same time?
LeonWaksman
 I understand that in the USB C port you are using USB C DP to VGA converter. Usually both ports HDMI and  USB C Thunderbolt may simultaneously feed two separate display, however to be sure I need to know your NUC model.
Leon
