hello.
I Have a mini NUC. it used to work fine with BENQ display.
suddenly, when I try to work it says on my desktop HDMI no signal.
I don't understand why and what can I do
thank you for your help
Did you rearrange your work area, and perhaps swap ends on the hdmi cable? If so, swap the ends again. Some HDMI cables are directional.
Doc
Hello, kimiku.
I would like to know if you could follow the steps provided by Al Hill. If that did not work for you, in order for me to assist you better, please provide me with the .txt file that the https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- System Support Utility will generate. To attach a file, you must click the "Attach" option on the bottom right-hand corner of the response box.
Antony S.
