Intel® NUCs
Support for Intel® NUC products
The Intel sign-in experience is changing in February to support enhanced security controls. If you sign in, click here for more information.
12545 Discussions
HDMi display issues with NUC and TVs??
CraigH
Is there a solution to the NUC HDMi issues with TVs?
Looked in a few posts but cant find a resolution to the HDMi signal not being detected by tvs after power off.
Currently i unplug NUC and take it to a computer monitor to then be able to see a display.  Perform any updates.  Then take it back to TV where it works for a couple months ( only booted up 5x a month) before issue repeats again.
AlHill
I have several NUCs on TVs, and they work fine.
So the Intel support engineers can have more information about your system, Please download and run the Intel System Support Utility (https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- ) for Windows. Select all data categories and then have it generate a report. Next, have the tool Save the report to a text file (don't try to use the Submit capability; it doesn't work). Finally, using the Drag and drop here or browse files to attach dialog below the edit box for the body of your response post, upload and attach this file to the response post.
[Windows 11 is the new Vista]
