Intel® NUCs
Assistance in Intel® NUC products
13292 Discussions
HVK USB restarts machine
JThor5
Hi all
I've been using a NUC8i7HVK for a couple of weeks now and I am absolutely loving this little thing!
However I have stumbled upon something that makes me think there might be a problem with my unit...
I noticed that if i plug a USB cable into the yellow USB port on the front of the device, it immediately restarts my system.
-all lights turn off, then come back on again and the system boots back up.
Oddly enough, this only seems to happen if the USB cable I plug in doesn't have anything attached on the other end - plugging in say memory stick, or my phone with the phone plugged in first..
Pretty sure its not the cable as I cannot reproduce this issue on any of the other usb ports with the same cable.
Has anyone else come across this before?
Hello lilsancho,
I understand that you are having problems related to the yellow USB port.
Regarding this, I would like to share with you the following article:
https://www.intel.com/content/www/us/en/support/articles/000029060/mini-pcs/intel-nuc-kits.html https://www.intel.com/content/www/us/en/support/articles/000029060/mini-pcs/intel-nuc-kits.html
This article is related to your current problem, I would recommend you to try one of the options available for a fix.
David V
Hello lilsancho,
David V
JThor5
Thanks David V
I think this may have been the cause!
I added a little extra insulation around those wires (on inspection they didn't appear to be damaged) and the problem seems to have gone away!
Seems like it would have made more sense to solder the wires at the center of those pads for more clearance rather than at the leading edge.
Never mind, I'm a happy chappy for now!
Ray_W_Intel
The recommendation by the above support agent looks pretty spot on.
In addition to the linked document, If you find that you don't wish to use your digital microphone array on the system itself you can also unplug the whole array by unplugging the white connector that is attached to the 4 digital microphones that is close to the memory slots.
