Intel® NUCs
Support for Intel® NUC products
The Intel sign-in experience is changing in February to support enhanced security controls. If you sign in, click here for more information.
12544 Discussions
HVK - leds and lights not working
SamRyan
My HVK NUC recently started having issues with the leds, particularly the skull and the front lights.
After turning it on, no lights at all came on or were working. After 5 minutes, one light came on and stayed solid until I turned it off. Several restarts no fix. After a day, I turned it on and all lights back on and working.
Anyone else have this issue?
n_scott_pearson
Super User Retired Employee
I have seen some strangeness as well. I go into the LED Manager and simply click to reload my configuration and voila! it's fixed.
SamRyan
Tried with mine.. unfortunately no luck... The LED manager has been busted for months, used to sit in the dock but now it wont auto start. Even tried redownloading to no luck.
Unplugging power for 10 minutes helped.. but shouldn’t have to. Will keep an eye on it. Might reflash and restore bios 63
Sebastian_M_Intel
Hello SRyan10,
Thank you for posting on the Intel® communities.
There may be several reasons why the LED lights are not working, try the following steps: https://www.intel.com/content/www/us/en/support/articles/000029598/intel-nuc/intel-nuc-kits.html
1. LED lights are disabled from Tray Application
When the LED Manager for Intel® NUC is launched an icon will appear in the tray to allow quick control of the LEDs. The tray application will continue running even if the main UI application is closed. Selecting Disable All from the tray menu will turn off all of the LEDs on the NUC. To enable Lights, follow these steps:
  1. Access the application.
  2. Select drop-down menu on each light section
  3. Turn it up
  4. Do the same with each light section
2. LED cable inside the chassis is disconnected:
Remove the six screws on top of the chassis, using the hex key that was included in the box, and remove the cover.
Check the three cable connections on the top plate to be sure they are fully connected.
Unscrew the small silver screw to release the top plate.
Check the cable connection to the motherboard to be sure it is fully connected.
Replace the plate and top cover, then test the LEDs again.
3. Power issue, check if the same issue happens with a different power adapter or power outlet.
4. Update the BIOS to the latest version available:
Download link: https://downloadcenter.intel.com/download/29832/BIOS-Update-HNKBLi70-86A-?product=126143
BIOS update steps: https://www.intel.com/content/www/us/en/support/articles/000005636/intel-nuc.html
Sebastian M
Intel Customer Support Technician
Sebastian_M_Intel
Hello SRyan10,
Were you able to check the previous post and get the information requested? Please let me know if you need more assistance.
Sebastian M
SamRyan
Hi Seb
A simple restore defaults in the bios fixed the issue, but i plan to reflash 063.
all cables were secure.
Sam
Sebastian_M_Intel
Hello SRyan10,
Thank you for your update.
If you want, you can try the BIOS recovery and let us know about the outcome. You may already have them but you can check the BIOS recovery instructions here: https://www.intel.com/content/www/us/en/support/articles/000005636/intel-nuc.html
Sebastian M
Sebastian_M_Intel
Hello SRyan10,
By any chance, do you have an update on this? Were you able to complete the BIOS recovery? Please let me know if you need more assistance.
Sebastian M
SamRyan
Hi Seb
All sorted at this stage will monitor.
Sam
Sebastian_M_Intel
Hello SRyan10,
Thanks for your reply.
In that case, we will proceed to close this inquiry; if you get to have any issues in the future, please submit a new thread and we will gladly assist you.
Sebastian M
