Hi to all Hades Canyon NUC8i7HVK Users I have noticed that my Bus Speed has been dropping over time could you please check and post your bus speeds. As I would like to see if it is isolated to my system or wide spread. My NUC has been in daily use since the 25 May 2018.
As System Bus Speed is dropping all other elements also lose speed and performance.
Bus Speed should be 100MHz but is any where between 99.70MHz and 99.80MHz
Thanks to all who respond.Bus Speed
Windows Version 2004, Build 19041.488
Intel® NUC Hades Canyon NUC8i7HVK
Intel Core i7-8809G 3.1GHz 4.2GHz Turbo 4 Cores 8 Processor's O/C to 4.6GHz
32GB Ram 2x 16GB DDR4 2400+ SODIMMs O/C to 2600
Razer Core X - E-GPU Fitted with a Radeon RX 5700 O/C to 2011MHz
Has been flashed with the Radeon 5700 XT Bios
512 GB M.2 SATA SSD Operating System and Apps
1TB M.2 SATA SSD Game's only Windows and Steam
I set mine to 101 in XTU and it bounces around between 100 and 101 but never lower than 100.
Thanks for the Reply that is what mine use to look like, and I have no Idea just why it is dropping.
Will have a look at the at the Tuning Utility last time I tried it the program just kept crashing.
Well looks like it is fixed installed the program started it up and now stable at 100.10MHz to 100.15MHz
Will have it see if it stays nice and steady after a couple of days.
100Mhz for me (or 99.87Mhz in realtime).
