Intel® NUCs
12333 Discussions
Hades Canyon Powering Up Problem
MDavi22
Hello Everyone!
My HVK has an interesting behavior. Nothing happens when I insert power cable to NUC and press power button afterward but If I press the power button while inserting power cable it works. Also, if I turn off my unit, I must detach the power cable and repeat the same procedure or else it doesn't boot.
Is there any solution to this?
Thank you in advance
Community Manager
Hello MigDavid
Thank you for joining the community.
Have you tried other power outlet and another power cable to test the unit?
Leonardo C.
MDavi22
I have tried several power outlets but none solved the issue. The HVK kit is brand new and I have no other power adapter to try it.
I would like to be a bit more elaborate on this matter;
The LED on front panel blinks up as a white color for about 0.2 seconds when energy is fed to the unit. At this moment, the power button has to be pressed for NUC to boot up. Otherwise, the device doesn't respond in any way. Holding the button down or firmly pressing it doesn't work either.
Additionally, pressing on the power button or holding it down while using the device (OS booted up) has no response as well. Initially, I thought that this could be a BIOS problem, so I upgraded it to vers. 0040 in BIOS menu but nothing has changed.
Apart from the above-mentioned issue, NUC works flawlessly.
n_scott_pearson
Super User Retired Employee
After this brief light up, hold the power button in for a full 4+ seconds. This should clear the NUC to the S5 state. When you then touch the power button again, you should then be able to see whether the LED on the power button flashes to signal some specific problem occurring.
Hope this helps,
MDavi22
Thanks for your suggestion.
After many attempts, I have figured out that the problem was related to the power button. Under the assumption of having the audible feedback on power button was enough push to turn the device on, I had not used more force on it. Turns out more strength has to be applied on power button make it work. Do you have the similar case in your device too?
MLevi
Valued Contributor I
I play guitar, everything is a hard push :-)
EMene3
I have a similar problem and just found this forum. My 8i7HVK has been a real beauty for more than 1 year now, I simply love it. But suddenly I am having power issues. I won't turn on anymore. Twice I have been able to turn it on after the front tiny LEDs flashed quickly white, and could work on it without any problem. But next day was completely dead. Changed power outlets, moved RAM and SSD to the second slot, etc with no results. Then at midday I saw the LEDS flash again white. Pressed the power button and it powered up for 2 seconds, then off. Since then it's plain dead. I am having intel support online now but if someone has experienced and solved this I will really appreciate feedback
dldx11
I have this exact issue - if anyone has any pointers please do shout- I love this NUC and don’t want to scrap it at all...
Jan3
Hi
Can somebody help with schematic files for this NUC? I have one which is not powering on at all . I figure it out that lots of voltages are missing but is hard to find the issue without the schematic. Thank you in advance
best regards
n_scott_pearson
Intel does not release schematics externally under any circumstance. If you are an intel employee, you should use internal paths to contact the SPG NUC team and talk to them about access.
aviegas
I'm having the same problem with my NUC8i7HNK. It was working fine and now it just flashes all LEDs when power is applied. Once I was able to get it to respond to 4+ seconds "reset" and it worked for a few boots and "survived" a few removals of the power cord. Left it without the power cord overnight and on the next morning, the same problem. Now I can't get it to boot again.
Interesting this all started after a BIOS upgrade. I was running 0059, if not mistaken, and upgraded to the latest  0064. 0059 is quite old (If I recall correctly it's the first version that solved the Linux/VMWare boot on the HNK - I use the NUC with VMWare). The BIOS upgrade was done running Windows 10 (latest), as I have to setup a Windows machine for a project (hence when adding device drivers there was the option to upgrade the BIOS and I did it). Don't know if this is related.
Anyone has solved this issue, aside from tossing it out and getting a new one (out of warranty now)? It's really strange that at least 3 people here describe the same exact issue.
If I get it to restart, I will attempt to downgrade the BIOS, if I have the old files.
n_scott_pearson
@aviegas,
Everyone's situation is different. Please use the Ask a Question button on the main Intel Community page to begin a discussion regarding your issue.
