Community
cancel
Showing results for
Search instead for
Did you mean:
RSter4
Hades Canyon
Hi, Just trying to understand if the new Hades Canyon, due for release soon, supports Intel Optane memory?
Community Manager
Hello, OzBrewer.
Thank you very much for contacting the Intel® Communities Team.
Allow me to share with you that the https://www.intel.com/content/dam/www/public/us/en/documents/product-briefs/optane-memory-brief.pdf Intel® Optane™ Memory (page 3, Supported Platforms section) will be compatible with 7th Generation or newer Intel® Core™ Processor-based Platforms. The Hades Canyon NUCs (https://ark.intel.com/products/126143/Intel-NUC-Kit-NUC8i7HVK?q=NUC8i7HvK Intel® NUC Kit NUC8i7HVK and https://ark.intel.com/products/126141/Intel-NUC-Kit-NUC8i7HNK?q=NUC8i7HNK Intel® NUC Kit NUC8i7HNK) have an 8th Generation Intel® Core™ Processor as a result, this NUC is compatible with the Optane™ memory.
I hope this answers all your questions.
Antony S.
LeonWaksman
Hello Oz,
How you intend to use Optane memory in Hades Canyon? Since there is now bay for HDD, but two M.2 slots for SSD I don't see any advantage to use in this NUC Optane memory.
Leon
n_scott_pearson
Super User Retired Employee
Leon,
I started to answer that I agree with your assessment and question, but then I remembered that there is a way (or is it a version?) that allows Optane memory to be used as a super-fast standalone SSD (rather than as a caching accelerator for a separate HDD). In this case, it is a legitimate question being asked (and the answer is yes, it should be supported).
LeonWaksman
Hi Scott,
Yes, you may use Intel Optane memory as a standalone NVMe SSD, however, Intel doesn't supports this configuration. In addition I don't see any reason to buy an 32 GB Optane memory for 60$ and using it as SSD (more than 20GB will be consumed by Windows), instead of buying for additional 60$ Samsung 960 EVO 250GB NVMe drive. So, I thing that both - the question and the answer are irrelevant.
Leon
RSter4
I'm looking at getting a WD 512GB Black PCIe M.2 SSD Drive.
And I was wondering if the Optane memory would be worth purchasing as a caching accelerator to supplement the WD SSD.
Just not sure how it would work and hang together.
LeonWaksman
Hi Oz,
I will not pair Optane memory with an NVMe SSD. You will have only marginal (if any) performance improvement. Instead of wasting money on quite expensive Optane memory, in this case I'll suggest to consider
Samsung 960 EVO M.2 MZ-V6E500BW 500GB SSD. Samsung's 960 EVO beats the WD Black across the board.
Leon
RSter4
Thanks Leon. I really appreciate you taking the time to answer.
I'll take a good look at the Samsung 960 evo then, and scrap the idea of the Optane memory.
