dimensions of the fixing holes for the cpu cooling block? planning on modding it as the cooling is poor.
- This is link to Intel NUC Kits and boards mechanical drawings. https://www.intel.sg/content/www/xa/en/support/articles/000006820/mini-pcs.html
- I suggest that before you make any chages, check if both fans working and if the cooling solution is clean from dust. In my opinion Hades Canyon cooling is very good, except if your NUC is located in unusual environment.
Leon
