this is not a monitor but a high quality 4K and HDR10 TV namely the Loewe image 5.55 OLED.
At the weekend I noticed that Windows 10 Pro had simply encrypted the hard drives with Bitlocker.
After decrypting both hard drives, the error was not completely gone, the switch still takes 20-30 seconds, but it will always be switched.
In addition, I have already taken a fairly high quality cable because of the 4K in HDR transmission for connecting the NUC to the TV.
I have taken over the complete M2 SSD and the 2.5 inch HDD of the predecessor NUC i5 in the nine i8 and that worked fine after the driver installation.
Unfortunately, Windows 10 Pro has disabled so I had to buy a new Windows license and had to completely reinstall the system. Since then I have the problem with switching.
I attached the content of the report file below.
Wolfgang Bisinger
********************************BEGINN
# SSU Scan Information
Scan Info:
Version:"2.5.0.15"
Date:"05.29.2019"
Time:"00:00:23.6784442"
# Scanned Hardware
Computer:
BaseBoard Manufacturer:"Intel Corporation"
BIOS Mode:"UEFI"
BIOS Version/Date:"Intel Corp. BECFL357.86A.0071.2019.0510.1505 , 10.05.2019 12:00"
CD or DVD:"HL-DT-ST BD-RE BU40N USB Device"
Embedded Controller Version:"3.20"
Platform Role:"Desktop"
Processor:"Intel(R) Core(TM) i3-8109U CPU @ 3.00GHz , GenuineIntel"
Secure Boot State:"On"
SMBIOS Version:"3.2"
Sound Card:"Intel(R) Display-Audio"
Sound Card:"Realtek High Definition Audio"
System Manufacturer:"Intel(R) Client Systems"
System Model:"NUC8i3BEH"
System SKU:"BOXNUC8i3BEH"
System Type:"x64-based PC"
- "Display"
Intel ® Graphics Driver Version:"25.20.100.6519"
- "Intel(R) Iris(R) Plus Graphics 655"
Adapter Compatibility:"Intel Corporation"
Adapter DAC Type:"Internal"
Adapter RAM:"1,00 GB"
Bits Per Pixel:"32"
- "Caption":"Intel(R) Iris(R) Plus Graphics 655"
Link:"
http://www.intel.com/content/www/us/en/search.html?keyword=Iris+Plus+Graphics+655"
CoInstallers:"oem20.inf,iCFL_w10_DS,Internal,Intel(R) Iris(R) Plus Graphics Family"
Color Table Entries:"4294967296"
Dedicated Video Memory:"Not Available"
Driver:"igdkmd64.sys"
Driver Date:"01.09.2019 01:00"
Driver Path:"
C:\Windows\system32\DriverStore\FileRepository\iigd_dch.inf_amd64_cceda4256e54c62c\igdkmd64.sys"
Driver Provider:"Intel Corporation"
INF:"oem20.inf"
INF Section:"iCFL_w10_DS"
Install Date:"Not Available"
Installed Drivers:"
C:\Windows\System32\DriverStore\FileRepository\iigd_dch.inf_amd64_cceda4256e54c62c\igdumdim64.dll,C:\Windows\System32\DriverStore\FileRepository\iigd_dch.inf_amd64_cceda4256e54c62c\igd10iumd64.dll,
C:\Windows\System32\DriverStore\FileRepository\iigd_dch.inf_amd64_cceda4256e54c62c\igd10iumd64.dll,C:\Windows\System32\DriverStore\FileRepository\iigd_dch.inf_amd64_cceda4256e54c62c\igd12umd64.dll"
Last Error Code:"Not Available"
Last Error Code Description:"Not Available"
Last Reset:"Not Available"
Microsoft DirectX* Version:"DirectX 12"
Monochrome:"No"
Number of Colors:"4294967296"
Number of Video Pages:"Not Available"
PNP Device ID:"PCI\VEN_8086&DEV_3EA5&SUBSYS_20748086&REV_01\3&11583659&0&10"
Power Management Capabilities:"Not Available"
Power Management Supported:"Not Available"
Refresh Rate - Current:"60 Hz"
Refresh Rate - Maximum:"60 Hz"
Refresh Rate - Minimum:"23 Hz"
Resolution:"3840 X 2160"
Scan Mode:"Noninterlaced"
Service Name:"igfx"
Status:"OK"
Video Architecture:"VGA"
Video Memory:"Unknown"
Video Processor:"Intel(R) Iris(R) Plus Graphics Family"
- "Memory"
Physical Memory (Available):"4,97 GB"
Physical Memory (Installed):"8 GB"
Physical Memory (Total):"7,84 GB"
- "Memory Channel A"
Capacity:"8 GB"
Channel:"SODIMM1"
Configured Clock Speed:"2400 MHz"
Configured Voltage:"1200 millivolts"
Data Width:"64 bits"
Form Factor:"SODIMM"
Interleave Position:"Noninterleaved"
Manufacturer:"859B"
Maximum Voltage:"Not Available"
Memory Type:"Unknown"
Minimum Voltage:"Not Available"
Part Number:"CT8G4SFS824A.C8FBD1"
Serial Number:"E12B8CC0"
Status:"Not Available"
Type:"Synchronous"
- "Motherboard"
BIOS:"BECFL357.86A.0071.2019.0510.1505, INTEL - 47"
Caption:"Hauptplatine"
Chipset:"Not Available"
Date:"05.10.2019 02:00"
Model:"Not Available"
Part Number:"Not Available"
PNP Device ID:"Not Available"
Product:"NUC8BEB"
Serial Number:"GEBE83800F8Q"
Status:"OK"
Version:"J72693-303"
- "Networking"
Intel ® Network Connections Install Options:"ANS,DMIX"
Intel ® Network Connections Version:"23.5.2.0"
Intel ® PROSet/Wireless Software Version:"Not Available"
- "Bluetooth Device (Personal Area Network)"
Caption:"Bluetooth Device (Personal Area Network)"
CoInstallers:"Not Available"
Default IP Gateway:"Not Available"
DHCP Enabled:"Yes"
DHCP Lease Expires:"Not Available"
DHCP Lease Obtained:"Not Available"
DHCP Server:"Not Available"
Driver:"bthpan.sys"
Driver Date:"06.21.2006 12:00"
Driver Path:"
C:\Windows\system32\drivers\bthpan.sys"
Driver Provider:"Microsoft"
Driver Version:"10.0.17763.1"
Index:"0012"
INF:"bthpan.inf"
INF Section:"BthPan.Install"
Installed:"Yes"
IP Address:"Not Available"
IP Subnet:"Not Available"
Last Reset:"05.28.2019 10:01"
MAC Address:"04:D3:B0:81:65:EA"
Manufacturer:"Microsoft"
Media Type:
Net Connection ID:"Bluetooth-Netzwerkverbindung"
NetCfgInstanceId:"{531EA96C-43E1-409C-8E45-AEB89E6CA65E}"
Number of VLANs:"0"
PNP Device ID:"BTH\MS_BTHPAN\6&2776B02B&0&2"
Port:"Not Available"
Power Management (Low Power):"Not Available"
Power Management (Wake On LAN):"Not Available"
Power Management (Wake on Magic Packet):"Not Available"
Power Management Supported:"No"
Product Type:"Bluetooth Device (Personal Area Network)"
Service Name:"BthPan"
Status:"Enabled"
Team Name:"Not in a team"
Temperature:
Type:"Ethernet 802.3"
- "Service Bindings"
Antwort für Verbindungsschicht-Topologieerkennung:
Client für Microsoft-Netzwerke:
Datei- und Druckerfreigabe für Microsoft-Netzwerke:
E/A-Treiber für Verbindungsschicht-Topologieerkennungszuordnung:
Internetprotokoll, Version 4 (TCP/IPv4):
Internetprotokoll, Version 6 (TCP/IPv6):
Microsoft-LLDP-Treiber:
- "Intel(R) Ethernet Connection (6) I219-V"
- "Caption":"Intel(R) Ethernet Connection (6) I219-V"
Link:"
http://www.intel.com/content/www/us/en/search.html?keyword=Ethernet+Connection+(6)+I219+V"
Default IP Gateway:"192.168.178.1;fe80::ca0e:14ff:fe72:4db4"
DHCP Enabled:"Yes"
DHCP Lease Expires:"09.26.1932 10:26"
DHCP Lease Obtained:"09.16.1932 10:26"
DHCP Server:"192.168.178.1"
Driver:"e1d68x64.sys"
Driver Date:"01.24.2019 12:00"
Driver Path:"
C:\Windows\system32\DriverStore\FileRepository\e1d68x64.inf_amd64_9b64147bed2d44a1\e1d68x64.sys"
Driver Provider:"Intel"
Driver Version:"12.18.8.9"
ETrackID:"0x00000000"
Index:"0013"
INF:"oem47.inf"
INF Section:"E15BE.10.0.1"
Installed:"Yes"
IP Address:"192.168.178.50;fe80::a1a2:8a35:efba:5df;2001:16b8:248b:c300:a183:a8:cd0:8116;2001:16b8:248b:c300:a1a2:8a35:efba:5df"
IP Subnet:"255.255.255.0;64;128;64"
MAC Address:"94:C6:91:A4:C9:65"
Manufacturer:"Intel"
Media Type:"Kupfer"
Net Connection ID:"Ethernet"
NetCfgInstanceId:"{CBE2A0D8-BAAD-4656-BEF9-BEEA68A64C0A}"
Number of VLANs:"0"
NVM Version:"0x00000000"
Part Number:"FFFFFF-0FF"
PNP Device ID:"PCI\VEN_8086&DEV_15BE&SUBSYS_20748086&REV_30\3&11583659&0&FE"
Power Management (Low Power):"Active: Yes, Enable: Yes"
Power Management (Wake On LAN):"Active: Yes, Enable: Yes"
Power Management (Wake on Magic Packet):"Active: Yes, EnableWakeOnMagicPacketOnly: No"
Product Type:"Intel(R) Ethernet Connection (6) I219-V"
Service Name:"e1dexpress"
Status:"Verbindung aktiv"
Temperature:"Nicht unterstützt"
QoS-Paketplaner:
- "Settings"
*FlowControl:Flusssteuerung:"Rx und Tx aktiviert (3)"
*InterruptModeration:Interrupt-Drosselung:"Aktiviert (1)"
*IPChecksumOffloadIPv4:IPv4-Prüfsummen abladen:"Rx und Tx aktiviert (3)"
*JumboPacket:Jumbo Packet:"Deaktiviert (1514)"
*LsoV2IPv4:Large-Send-Offload V2 (IPv4):"Aktiviert (1)"
*LsoV2IPv6:Large-Send-Offload V2 (IPv6):"Aktiviert (1)"
*NumRssQueues:Max. Anzahl RSS-Warteschlangen:"2 Warteschlangen (2)"
*PMARPOffload:Protokoll-ARP-Abladung:"Aktiviert (1)"
*PMNSOffload:Protokoll-NS-Abladung:"Aktiviert (1)"
*PriorityVLANTag:Paketpriorität und VLAN:"Paketpriorität und VLAN aktiviert (3)"
*ReceiveBuffers:Empfangspuffer:"256 (256)"
*RSS:RSS (Empfangsseitige Skalierung):"Aktiviert (1)"
*SpeedDuplex:Geschwindigkeit und Duplex:"Automatische Aushandlung (0)"
*TCPChecksumOffloadIPv4:TCP-Prüfsummen abladen (IPv4):"Rx und Tx aktiviert (3)"
*TCPChecksumOffloadIPv6:TCP-Prüfsummen abladen (IPv6):"Rx und Tx aktiviert (3)"
*TransmitBuffers:Übertragungspuffer:"512 (512)"
*UDPChecksumOffloadIPv4:UDP-Prüfsummen abladen (IPv4):"Rx und Tx aktiviert (3)"
*UDPChecksumOffloadIPv6:UDP-Prüfsummen abladen (IPv6):"Rx und Tx aktiviert (3)"
*WakeOnM
