Intel® NUCs
12309 Discussions
Hard Power down of Intel NUC10
Tman
I have an application where the NUC needs to switch off instantaneously when power is removed. It then has to switch on upon the presence of power (this part is done).
Could i please get guidance as to achieve this without damage to the NUC. I have no options in this application but to switch off the NUC hard. Basically the power will be suddenly removed once the session is finished.
IS there anything which need to be done to ensure safe and reliable startup on the presence on supply returning.
thanks,
T
David_G_Intel
Hello Tman
Thank you for posting on the Intel️® communities, please share with us the full model of the NUC or SA#. Also, which application do you use specifically?
David G
David_G_Intel
Hello Tman
We understand you have opened a chat ticket with us and we will continue to help you through that channel now. We will therefore close this community case. Thank you.
David G
