Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Harmony and Sky Remote power button causes DN2820FYK to power on as well as the Sky+ Box
When using a Sky remote or my harmony remote to turn my Sky box on or off, my NUC turns itself on. I guess this means they must both be listening for the same code? Is it possible to change the code the nuc is listening for or does anyone have another idea as to how to solve this?
Highlighted
Re: Harmony and Sky Remote power button causes DN2820FYK to power on as well as the Sky+ Box
Luke,
For a time I had 2 NUCs in the same room and wasn't able to use the remote with only one (they were on opposite sides of the room). I haven't found a setting in the BIOS or the drivers that lets you change the code. I "resolved" that problem by not having them in the same room, but it would be interesting to know if anyone has found a solution. It's similar to having 2 identical tvs or bluray players in the same room.
Jason
