Community
cancel
Showing results for
Search instead for
Did you mean:
JWill37
Has anybody tried the little Canon RC6 remote with an Intel NUC6i7KYK Skull Canyon?
I have found this little Canon RC6 remote
http://www.eos-magazine.com/articles/remotes/canonrc6.html http://www.eos-magazine.com/articles/remotes/canonrc6.html
I was wondering if this could be used to power on (from s5) a Intel NUC6i7KYK Skull Canyon?
It doesn't have to do anything else, just power on from s5.
And if nobody has tried, what would be the easiest way to try to do this?
Any suggestions for BIOS/Windows (Pro) 10 settings?
Thanks for the help!
Jan
Community Manager
Hello johnnydub,
Thank you for joining the Intel® NUC Community.
From my end, these are the remote control that have been officially tested; http://compatibleproducts.intel.com/ProductDetails/ExportPeripheralInfo?moduleName=Intel%C2%AE%20NUC... http://compatibleproducts.intel.com/ProductDetails/ExportPeripheralInfo?moduleName=Intel%C2%AE%20NUC...… .Maybe the community can add more feedback regarding this specific set up.
Amy C.
n_scott_pearson
Super User Retired Employee
Well, I can attest that the KY NUCs can definitely be powered on using a RC6-compliant remote (it does so using my Rosewill RHRC-11001). Now, whether this Canon remote can actually do the same thing is unknown. I have my doubts. First of all, this remote is named the RC-6; I don't see anyplace in the article where it says that this remote is actually compliant with the RC6 "standard". Secondly, in order for a remote to actually be able to wake up a NUC, it must be capable of sending the Sleep Button RC6 sequence. As I look at this remote and its usage description, it doesn't read like there is any capability to configure it for this. Either way, the proof is in the pudding. With doubts raised, I wouldn't want to utilize a try-before-buy model...
As for configuration, I only had to change the BIOS configuration to get this working. At boot, use F2 to enter BIOS Setup (Visual BIOS) and then select Advanced and then Power. In the Secondary Power Settings window on the right side of the screen, you want to enable (check) parameters Wake from S3 via CIR and Wake from S4 and S5 via CIR. That's it.
Hope this helps,
