Intel® NUCs
Assistance in Intel® NUC products
All support for Intel® NUC 7 - 13 systems is transitioning to ASUS. Read more.
13515 Discussions
Hello, Since GCC I can't change my active display resolution (NUC8) I set 1920x1080 in GCC or display resolution in windows panel but active signal resolution is set to 3840x2060p. How can change the active signal resolution ? Thanks.
PSavo
AlHill
What is the model number of your NUC?
What version of Windows 10? 1909?
PSavo
Hi, Sorry, it is NUC8I5BEH ( Iris 655) and yes, last clean updated win 10 po (1909) I think it's related with the new gcc scaling model Le mar. 25 févr. 2020 à 13:33, Intel Forums <supportreplies@intel.com> a écrit :
AdrianM_Intel
Hello PSavo,
Do you still need assistance? if so please provide the following information:
Please run the following tools and attach the reports generated.
1. Intel® System Support Utility (Intel® SSU)
  • Intel® SSU Download link
  • Open the application and click on "Scan" to see the system and device information. By default, Intel® SSU will take you to the "Summary View". \
  • Click on the menu where it says "Summary" to change to "Detailed View".
  • To save your scan, click on "Next", then "Save".
2. DXDIAG
  • Go to Start > Run or Windows Key + R.
  • On the Run prompt, type "dxdiag" then click OK.
  • On the DirectX Diagnostic Tool window, click on Save All Information.
  • Browse to a folder, type in a filename then click Save.
Please provide the steps that you are doing when you change the settings.
Adrian M.
AdrianM_Intel
Hello PSavo,
Were you able to check the previous post?
Let me know if you need more assistance
Adrian M.
AdrianM_Intel
Hello PSavo,
We have not heard back from you, so we will close this inquiry. If you need further assistance, please post a new question.
Adrian M.
