Intel® NUCs
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
11980 Discussions
Help needed on device not starting
mMore8
I have a BOXNUC7I5BNHX1 and since a few days ago when I turn off the computer it is impossible to restart it. After several attempts, the screen is activated and this happens everytime I need to use it. It also happens now and then that the screen turns completely black while using it, and it only gets solved by trying to reboot it again many times.
Can someone help me please?
n_scott_pearson
Super User Retired Employee
I have seen a few NUCs suffer a power interlock. It feels like a ground loop has formed but I haven't verified this. Anyway, disconnect the NUC from its power brick for 30 seconds and then reconnect and see if this restores its ability to power up.
Hope this helps,
LeonWaksman
1. You didn't describe your hardware configuration.
2. Your Operating System?.
3. Are the all drivers updated?
4. Was the system working well before this failure happens?
5. Please download Intel System Support Utility: https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- Download Intel® System Support Utility for Windows* . Scan your system, save the result and attach the file with the results to your post.
Leon
