Intel® NUCs
12300 Discussions
Hi.i have a NUC8i7BEH and 2 monitor. This system only has one hdmi port I want to connect these two displays. Is it possible with usb c to hdmi convert?
khaji
khaji
tank you for your response, i have another question, could I apply the hdmi port of system for one monitor and use the type C port for the other monitor? Does the system able to recognize 2 monitors and we have 2 different displays for example to drag a window from one monitor to the other one? In fact I wouldn't like to have same display on both monitors at the moment.
AlHill
Your nuc will support 3 monitors. One on the hdmi, and two on the USB-C.
Doc
n_scott_pearson
Super User Retired Employee
But understand that (a) you need an adapter with a MST Hub to connect two monitors and (b) the two monitors connected to the USB-C are sharing the bandwidth of a single DisplayPort channel. You can run two 1080p monitors at 60Hz but 4K monitors will be limited to 30Hz.
