Intel® NUCs
12298 Discussions
Hi there.. I am getting following message while installing Intel XTU Extreme Tuning utility.. I am unable to install.
MChav10
[1F70:143C][2020-06-05T21:52:10]i001: Burn v3.11.1.2318, Windows v10.0 (Build 10240: Service Pack 0), path: C:\Users\F1\AppData\Local\Temp\{EABCE482-7AF5-492B-997D-1832460388BA}\.cr\XTUSetup.exe
[1F70:143C][2020-06-05T21:52:10]i000: Initializing string variable 'RemoveAllDataCheckboxValue' to value '[RemoveAllDataCheckbox]'
[1F70:143C][2020-06-05T21:52:10]i000: Initializing version variable 'BundleVersionNumber' to value '6.5.1.360'
[1F70:143C][2020-06-05T21:52:10]i009: Command Line: '-burn.clean.room=C:\Users\F1\AppData\Local\Microsoft\Windows\INetCache\IE\YE9TC8UP\XTUSetup.exe -burn.filehandle.attached=412 -burn.filehandle.self=404'
[1F70:143C][2020-06-05T21:52:10]i000: Setting string variable 'WixBundleOriginalSource' to value 'C:\Users\F1\AppData\Local\Microsoft\Windows\INetCache\IE\YE9TC8UP\XTUSetup.exe'
[1F70:143C][2020-06-05T21:52:10]i000: Setting string variable 'WixBundleOriginalSourceFolder' to value 'C:\Users\F1\AppData\Local\Microsoft\Windows\INetCache\IE\YE9TC8UP\'
[1F70:143C][2020-06-05T21:52:10]i000: Setting string variable 'WixBundleLog' to value 'C:\Users\F1\AppData\Local\Temp\Intel(R)_Extreme_Tuning_Utility_20200605215210.log'
[1F70:143C][2020-06-05T21:52:10]i052: Condition 'VersionNT >= v6.1' evaluates to true.
[1F70:143C][2020-06-05T21:52:10]i000: Setting string variable 'WixBundleName' to value 'Intel(R) Extreme Tuning Utility'
[1F70:143C][2020-06-05T21:52:10]i000: Setting string variable 'WixBundleManufacturer' to value 'Intel Corporation'
[1F70:1C10][2020-06-05T21:52:10]i000: Setting version variable 'WixBundleFileVersion' to value '6.5.1.360'
[1F70:143C][2020-06-05T21:52:10]i100: Detect begin, 1 packages
[1F70:143C][2020-06-05T21:52:10]i000: Product or related product not found: {823C3D41-1C6E-4ECA-9923-1200278AE478}
[1F70:143C][2020-06-05T21:52:10]i000: Setting version variable 'MsiAlreadyInstalledVersion' to value '0.0.0.0'
[1F70:143C][2020-06-05T21:52:10]i000: Setting string variable 'NETFRAMEWORK45' to value '394806'
[1F70:143C][2020-06-05T21:52:10]i000: Setting version variable 'WindowsDllVersion' to value '10.0.10240.16644'
[1F70:143C][2020-06-05T21:52:10]i101: Detected package: Intel_XtuInstaller.msi, state: Absent, cached: None
[1F70:143C][2020-06-05T21:52:10]i052: Condition 'BundleVersionNumber > MsiAlreadyInstalledVersion OR BundleVersionNumber = "0.0.0.0" OR NOT WixBundleAction = 5' evaluates to true.
[1F70:143C][2020-06-05T21:52:10]i052: Condition 'WixBundleInstalled OR VersionNT64 = "6.1.0.0" OR WindowsDllVersion >= "10.0.14393.0" OR NOT WixBundleAction = 5' evaluates to false.
[1F70:143C][2020-06-05T21:52:10]e000: This application is only supported on 64bit versions of Windows 7 or Windows 10 Anniversary Update (version 1607) or later.
[1F70:143C][2020-06-05T21:52:10]e000: Error 0x81f40001: Bundle condition evaluated to false: WixBundleInstalled OR VersionNT64 = "6.1.0.0" OR WindowsDllVersion >= "10.0.14393.0" OR NOT WixBundleAction = 5
[1F70:143C][2020-06-05T21:52:10]i199: Detect complete, result: 0x0
AlHill
And, your processor model number is? If it is not and X or K processor, your processor is not supported.
What version of WIndows 10? 1909? 2004?
Doc
