You have to be careful. I am being told that some MST Hubs simply split the DisplayPort channels and, while this might have worked with some previous NUCs, it won't work with the BE NUC (or HN/HV NUCs). If I understand the issue correctly, the MST Hub needs to make it look like the monitors are being daisy-chained. The obvious alternative is to use DisplayPort monitors that support daisy-chaining.
