Intel® NUCs
Assistance in Intel® NUC products
All support for Intel® NUC 7 - 13 systems is transitioning to ASUS. Read more.
13516 Discussions
High Definition Audio Device not plugged in
eman27
Good day guys,
Anyone experience this thing. I want to use my Bose TV speaker as desktop speaker.
My connection are:
from NUC8 via HDMI to Samsung Monitor (detected)
from NUC8 via HDMI to Bose speaker with HDMI ARC (undetected)
The sound will always come from the monitor. I tried the NUC8 using Analog to Bose speaker is working fine. Both HDMI not defective. I updated all my drivers, reinstall also, all the tricks but still I cant use my bose speaker using the HDMI directly connected from NUC8. Anyone can help. Thanks guys!
David_G_Intel
Hello eman27
Thank you for posting on the Intel️® communities. Please share more information with us to continue:
  • Intel® System Support Utility (Intel® SSU) results
    • Download the Intel SSU https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows
    • Open the application and select "Everything" click on "Scan" to see the system and device information. By default, Intel® SSU will take you to the "Summary View".
    • Click on the menu where it says "Summary" to change to "Detailed View".
    • To save your scan, click on "Next", then "Save".
  • Do you get the same problem without the ARC configuration?
  • Which drivers did you try?
  • What is the model of the Bose TV?
  • Did this configuration work before?
David G
David_G_Intel
David G.
David_G_Intel
David G.
