You need to ask your motherboard/system manufacturer what processors are compatible with their BIOS. Then, you can select from those.
Doc
Download, run, and save the results of this utility as a text file:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Then ATTACH the text file (using the paperclip under the toolbar).
Doc
