Intel® NUCs
12125 Discussions
How can I remotely or locally monitor A raid 1setup on a NUC8I7HVK? How will I be notified of a raid 1 failure?
SRick
I'm running a raid 1 with two M2 NVME drives.
David_V_Intel
Hello SRick,
Thank you for posting on the Intel ® communities.
I would like to know exactly how you created the RAID 1, did you create it using Intel ® Rapid Storage Technology or did you create it using Windows Disk Management?
If you created the RAID with Windows disk management then you could always re-create it using Intel ® Rapid Storage Technology so that you can manage it and check it in the best way; however, make sure to backup your information whenever you make any change to a RAID.
Refer to the link below in order to get Intel ® Rapid Storage Technology for the specific Intel ® NUC:
https://downloadcenter.intel.com/download/28220/Intel-Rapid-Storage-Technology-RAID-for-Windows-10-6...
I hope this helps.
David V
Under Contract to Intel Corporation
SRick
Hi David,
CanI RST be setup to notify me via email or text of a failure?
V/r
Scott
SRick
Hi David
I have not setup raid 1 yet. I planned to use the NUC bios to create a dual M.2 NVME raid 1. I did not know a software raid is required in addition to the NUC bios hardware raid. I am looking for the best way to monitor a NUC bios raid, remotely. I want to be notified of a failed M.2 NVME drive as soon as possible. Thanks for our advice.
V/r
Scott
David_V_Intel
Hello SRick,
Thank you for your response.
In this case, what we have to monitor the RAID locally is Intel ® Rapid Storage Technology, with the software you can monitor the status as well as turn notifications on so you can get e-mails if there is any negative event.
However, if you are looking for another way then I would like to mention that we only have Intel ® Rapid Storage Technology to do so, you can try looking for a third party solution that perhaps has been tried by a community peer here; nevertheless, from Intel's side we only provide Intel ® Rapid Storage Technology.
David V
