Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
How is the Driver Utility suppose to work?
Jump to solution
Hello all,
OK I follow that you have to look for drivers - found
There has to be drivers found that need to be installed - done
Download drivers - done
Click install button - isn't working
OK so whats the magic to getting this installed? Ideally there should be some feedback (maybe a progress bar?) that something is happening when you click the install button. Nothing at all!
NUC5i5RYH
Accepted Solutions
Highlighted
Holly cows! I got it to work! I just went through the same process over again and this time I got an active install button. I'm leaving it at that!
Highlighted
