Intel® NUCs
Support for Intel® NUC products
12506 Discussions
How many virtual machines can an i3 run?
Essereio
BXNUC10I3FNH with 16GB or 32GB hyperx memory.
I'm thinking of installing either Clear Linux or Fedora Linux and run Windows in a virtual machine when I need it.​ How many virtual machines can this i3 NUC run?
WChen193
It depends on your needs. My laptop's processor is i5 7200U, which is weaker than i3 10110U, and I can run 2 virtual machines of Windows 7 on VMware smoothly at the same time. However I just use these virtual machines to test some simple programs. If you have demand for heavy work, I don't think this 2c4t processor can easily handle more than 2 virtual machines.
Essereio
How much RAM do you have installed? And does the video card use any of it?
n_scott_pearson
Super User Retired Employee
The general rule of thumb is 4 VMs per Core. On this processor, this would limit you to 8.
Essereio
Does the 4 VMs per Core apply to mobile CPU's?
n_scott_pearson
Good god man, this is a general rule of thumb, not a physical maximum or anything like that. Try it and see what it will do.
