Community
cancel
Showing results for
Search instead for
Did you mean:
JR1
How noisy is the new NUC8i7HVK / HNK
I cannot find anywhere the idle and max noise in decibels of the new NUC8i7HVK or NUC8i7HNK. Can anybody guide me where to get this data? Tx.
Tags (1)
Community Manager
Thank you very much for contacting the Intel Communities Team, James999.
Allow me to double check if this information is available, I will be back to you once I have an update.
Antony S.
Chris_V_Intel
Under what circumstances? Idle?, Max load?, etc.
JR1
cVare - before asking your question it would be nice if you READ the ORIGINAL post. This may help you to understand what I am asking for.
Chris_V_Intel
You are correct. My apologies. Let me see what I can find.
Chris_V_Intel
At 100% duty, it should run ~47 dBA.
Under "normal" room temp. it should be ~25dBA .
JR1
Thank you cvare.
Chris_V_Intel
No problem.
VZade
@cvare
could you link me to the source from which you got this info?
Chris_V_Intel
JR1
cvare Can you also send me the link to the source please. Tx.
Chris_V_Intel
The source is me asking the team for the information.
JR1
This is good but as far as I know there should be usually some mention about it in a specifications pdf and not just an answer from unspecified team member...
