Community
cancel
Showing results for
Search instead for
Did you mean:
DHaze
How should I partition memory in a NUC?
Disk 0 partition 1 is System Reserved at 100 MB with 71.0 MB free and is labeled System - the second partition is Disk 0 Unallocated space at 223.5 GB. I wiped out what was there chasing a nasty virus and I can't find any records on line about hoe the disk (memory) should be partitioned.
n_scott_pearson
Super User Retired Employee
Best result is to delete all partitions and then tell Windows to install to the (now) unpartitioned space. This lets Windows manage the partition table and choose the partition sizes it needs for optimal configuration.
DHaze
Thanks very much - it worked. I thought I had lost it but it came back good as new.
-- Deck
