Intel® NUCs
Assistance in Intel® NUC products
13307 Discussions
How to access TPM 2.0 simulator/device using Java program(Library)
Anupuy
Hi Team,
I am very new to TPM ,
I learned some basic TPM fundamentals.
I have downloaded TPM simulator (tpm2-simulator-chrisccoulson)  in ubuntu as well as windows(Windows TPM Simulator) runs on port 2321 to test the TPM simulator i have installed tpm2-tools and entered command it gives dev/tpm*** not found.(Currently i dont have Device).
Actual point is i want to connect TPM simulator/device using Java Library.
  1. Is there any Java based library for TPM.
  2. How to accessing TPM 2.0 simulator/device and generate SRK, storing certificate in TPM using Java library.
I referred this link: https://software.intel.com/content/www/us/en/develop/blogs/tpm2-software-stack-open-source.html
Thanks and regards
Anup Yalsangikar
Esteban_D_Intel
Hello Anupuy,
After checking your post and understanding your concern I would strongly recommend that you submit your question on the Intel® Developer Zone.
Please register, and create an account so that you can receive further troubleshooting support, and get access to useful documentation.
Intel® Developer Zone - Contact Page
https://software.intel.com/en-us/support
I hope this helps.
If you need any additional information, please submit a new question as this thread will no longer being monitored
Esteban D.
Intel Technical Support Technician
