Intel® NUCs
12315 Discussions
How to connect 3 independent displays to the 8v5PNK
DKosc
2 HDMI displays work fine in any combination of the 2 onboard HDMI ports and via the Thunderbolt 3 port using a USB-C to HDMI adapter.
Once I connect to the thunderbolt port, one of the HDMI ports stops working.
I've tried both a USB-C to HDMI adpater and the Sabrent TH-W3H2 which is a thunderbolt 3 display adapter.
I've installed the thunderbolt drivers from the intel site as well as the thunderbolt control center. The Sabrent device is recognized and works fine, but not at the same time as the 2 on board HDMI ports.
Thanks for any help you can offer.
Alberto_R_Intel
DKosc, Thank you for posting in the Intel® Communities Support.
In order to provide the most accurate information in reference to your inquiry, we will do further research on this matter, in order for us to be able to do that please provide the following information:
  • The model of all the USB-C to HDMI adapters that you have tested.
  • The model of all the monitors.
  • The HDMI cables, are they HDMI revision 2.0a?
  • Please provide the SSU report, to attach the report, once you choose "reply" select the "clip" icon on the lower-left corner:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-?product=91...
Albert R.
A Contingent Worker at Intel
Alberto_R_Intel
Hello DKosc, I just wanted to check if you saw the information posted previously and if you need further assistance on this matter?
Albert R.
DKosc
Thanks Albert. I did, then left on vacation. I'll be back next week and will resume this work.
Alberto_R_Intel
DKosc, You are very welcome, thank you very much for letting us know those updates.
Perfect, no problem at all, once you get the chance, please provide the information requested previously so we can further assist you with this matter.
Albert R.
Alberto_Sykes
Hello DKosc, I just wanted to confirm if you have the chance to provide the information requested previously and if you need further assistance on this matter?
Albert R.
Alberto_Sykes
Hello DKosc, If by any chance you need further assistance on this subject please post the information requested on your original thread.
Albert R.
Alberto_Sykes
Albert R.
DKosc
Albert,
I posted this earlier but now see that it wasn't accepted by the site.  Not sure why.  Here's a repeat:
Here are the specs of the cables & adapters I've tried.
Sabrent Thunderbolt 3 Dual HDMI 2.0 Display adapter - TH-W3H2
<https://www.sabrent.com/download/th-w3h2-user-manual/>
Cable Matters USB-C to 8K DisplayPort Adapter 201086
<https://www.cablematters.com/pc-1038-122-usb-c-to-displayport-adapter-usb-c-to-dp-adapter-with-8k-resolution-and-hdr-support.aspx>
Cable Matters DisplayPort 1.4 Cable 102025-6
<https://www.cablematters.com/pc-998-154-displayport-14-cable-8k-60hz-ready.aspx>
Insignia HDMI Cable 20B14T
<https://www.bestbuy.com/site/insignia-4-4k-ultra-hd-hdmi-cable-black/5938403.p?skuId=5938403>
The adapters and cables work when only 1 or 2 displays are attached.
When all 3 are attached, then the Thunderbolt and main HDMI work, but
not the secondary HDMI.
David.
Alberto_Sykes
Hi DKosc, Thank you very much for providing that information.
Besides that information about the cables, could you please provide the model of all the monitors being used?
Also, please attach the SSU report to the thread so we can verify further details about your platform:
Albert R.
Alberto_Sykes
Hello DKosc, I just wanted to check if you saw the information that was requested in the previous post and if you need further assistance with this matter?
Albert R.
DKosc
Here is the three monitors used
DELL p2412hb
Samsung SyncMaster T240 HD
Samsung S32D850T
DKosc
Here are the results for the scan
Alberto_Sykes
Hello DKosc, Thank you very much for sharing those details.
Please provide the SSU report so we can do further research on this matter:
Albert R.
DKosc
DKosc
Here are the attatchments
Alberto_Sykes
Hello DKosc, Thank you very much for providing the report.
We will do further research on this matter, as soon as I get any updates I will post all the details on this thread.
Albert R.
Alberto_Sykes
Hello DKosc, I just received an update on this matter.
In reference to your question, HDMI 2 and Type C Port cannot be used at the same time for multiple display configurations as you can confirm in the following link, at this moment your Intel® NUC is not showing there, but this link will be updated with the information below as soon as possible:
https://www.intel.com/content/www/us/en/support/articles/000005571/intel-nuc.html
Albert R.
n_scott_pearson
Super User Retired Employee
To explain this [Hint, hint Intel: hopefully some text similar to this will appear in their web page], the issue is that, because this NUC supports an Embedded DisplayPort interface, there are only two (other) DisplayPort channels available to support external displays. One channel was routed to the LSPCon IC that supports the HDMI1 connector. The other was routed to both the USB-C connector and the LSPCon IC supporting the HDMI2 connector. This is a smart routing; the BIOS recognizes which of the two connectors has monitor(s) connected to it and makes the routing exclusive to this connector. So, your choices are either,
  1. Connect a display to each of the HDMI1 and HDMI2 connectors. In this case, the USB-C connector will still be available to use for its USB 3.x functionality. Note that you will be limited to two external displays using this connection methodology.
  2. Connect a display to the HDMI1 connector and one or two display(s) to the USB-C connector. Two displays can be connected to the USB-C connector using either an MST Hub device or via DisplayPort Daisy-Chaining. Note that, if the Embedded DisplayPort interface is in use, you will be limited to two external displays as the processor design limits the total number of displays to three.
Hope this helps,
DKosc
Thanks for the explanation do you know make and model of the MST hub device that will work with Windows 10?
n_scott_pearson
It has nothing to do with Windows 10; it is a DisplayPort feature. Here are some examples:
  1. 2-Port USB-C to DisplayPort: https://www.amazon.com/gofanco-DisplayPort-Displayport-Thunderbolt-Compatible/dp/B07MF4QXFX.
  2. 3-port USB-C to DisplayPort: https://www.amazon.com/Accell-U226B-001B-DisplayPort-Multi-Monitor-Adapter/dp/B07F6CF61Z.
  3. 2-Port USB-C to HDMI: https://www.amazon.com/StarTech-com-2-Port-USB-C-HDMI-MST/dp/B06XPVGQKY.
  4. 3-Port USB-C to HDMI: https://www.amazon.com/StarTech-com-3-Port-USB-C-HDMI-Multi-Monitor/dp/B07667D37V.
I have #3 and it works fine. The others are examples only; I have not tried them.
My recommendation is to always use MST Hubs that are Thunderbolt 3-compatible.
