I would like to connect the AverMedia CN311-H M.2 HDMI In Capture Card to NUC7i5BNK?
This card has the connector to the M.2 interface and unfortunatelly this connector in this NUC is already occupied by disk SSD.
Is there any way to workaround this? For example connect another kind of disk to another connector, or use some adaptor?
regards,
Tomasz
Provide the model number of your NUC.
Doc
Hi Tomasz,
How about NVMe to USB 3.0 adapter or this. Those are examples. You may find many other adapters like this. You should ask the vendor what is the key on the connector.
Leon
Thank you for your interest in this topic
Product Code: BOXNUC7i5BNKP
Regulatory Model: NUC7i5BNK
Model No: 8265D2W
I was rather thinking about some M.2->SATA adapter, something similar to this one.
I will look for something I could use for connecting the SSD inside the NUC case.
regards
Tomek
