Intel® NUCs
12144 Discussions
How to do PXE on NUC?
Shuai_J_Intel
I try to install Windows by PXE. It reports "Image authorization fail. System can not boot to this device due to security violation"
So I disable secure boot in BIOS and try it again. It seems NUC cannot get IP.
Could anyone help me on this issue please?
Leonardo_C_Intel
Hello S
Thank you for posting in the Intel Community.
Is this error happening with the system connected by Ethernet cable? Is it possible to test the system connected to a USB to RJ45 adapter?
Hope this helps.
Leonardo C.
Under Contract to Intel Corporation
Leonardo_C_Intel
Hello S
Have you tested the USB adapter on the system?
Leonardo C.
Shuai_J_Intel
Hi Leonardo,
Thank you for your support. I tried USB adapter, it seem USB adapter cannot enabled by BIOS.
I also try to use "ifconfig -s eth0 dhcp" to get IP in EFI shell, but still fail. It seems disable "Secure Boot" will block network adapter.
Shuai
Leonardo_C_Intel
Hello S
Thank you for completing the testing. Allow me to investigate the installation that you are trying, I will be posting back as soon as possible.
Leonardo C.
Leonardo_C_Intel
Hello S
Thank you for waiting.
Make sure that you have followed these steps to enable PXE boot on the Intel NUC:
  1. Press F2 during boot to enter BIOS setup.
  2. Go to Advanced Settings and select the Boot Menu.
  3. Select Boot Configuration and uncheck Boot Network Devices Last.
  4. Then, from the Boot Configuration menu, go to Network Boot and enable UEFI PCE & iSCSI.
  5. Select either Ethernet1 Boot or Ethernet2 Boot.
  6. Pressing the F12 key during POST automatically forces booting from the LAN.
Test the system and if the behavior still persists you can contact your local Intel Customer Support for warranty options.
Reference link for support:
https://www.intel.co.uk/content/www/uk/en/support/contact-support.html
Leonardo C.
ATC_IT
Be advised, the Intel NUC does not recognize USB wireless keyboards until the OS Boots.  Using a wired keyboard resolved my issue without making any additional BIOS changes.
n_scott_pearson
Super User Retired Employee
That's patently not true. You most certainly can (I do it all the time). Are you sure you don't have one of those wireless keyboards whose Function keys only work when you (also) hold down a FN button? A lot of the Logitech wireless keyboards are like this.
