Community
cancel
Showing results for
Search instead for
Did you mean:
BHjal
How to get 4K resolution on Sony TV
I have installed Windows 10 (18-03) and all required drivers on a NUC8i7HVK connected to a LG 1080P TV.
Everything seems to work well. Now I want to use the NUC with a Sony 4K TV.
But when I connect it to the Sony TV the max resolution is still 1080P and I can't find any setup to increase it.
How to solve this, reinstall the graphic driver with the Sony TV connected or do something else?
BR/Gunnar
PVojt
How old is your cable?
HDMI2.0 cables are sometimes hit&miss (no matter of price). Although cheap I have good experience with PremiumCord cables.
Make sure they mention 4k@60Hz (doesn't have to be really HDMI 2.0 certified)
BHjal
After a second try (after no change?) I was able to set the resolution to 2016p and the other down to 1080p.
Problem solved!
BR
